Mills
Nov 27, 2011Aspirant
ReadyNAS Remote Duo V2 installation
I recently purchased a ReadyNAS Duo v2 and when I go to the add on tab to install readynas remote and click "get" a message comes up saying installation in progress, please wait for confirmation. I ...
hidetora
Jan 19, 2012Aspirant
calvinhoppes wrote: I am a little disappointed not to find a hint for a real solution. I don't want to loose all the time spend to understand my Duo V2.
Unfortunately I had to reboot the NAS and after the reboot procedure the ReadyNAS addons aren't working anymore:
- Photo II is not showing the port number 8086 in the configuration area (and thus is not working) and
- ReadyNAS remote is showing an error message: https://my-readynas.ip.
"The ReadyNSAS Remote addon is disabled, please enable it before launching this management page."
How is it possible to enable the addons? They are installed and at least Remote is showing a green dot.
Please help!?
I too have the same problem with my DUO v2 getting the '...please enable...' error message, I telephone technical support and in a rather embarrassed tone I was told that it is a know issue but Netgear don’t have the solution yet and no idea when it will be solved. Not the best of responses but at least I know its not me doing something wrong now, just wish Netgear would sort the problem out ASAP. Just thought anyone else reading this thread with this problem might like to know.
