Mills
Nov 27, 2011Aspirant
ReadyNAS Remote Duo V2 installation
I recently purchased a ReadyNAS Duo v2 and when I go to the add on tab to install readynas remote and click "get" a message comes up saying installation in progress, please wait for confirmation. I have waited over a day and it still says this. I have also done a factory reset and the message is still coming up. Please let me know if there is any additional information I can provide to solve this problem.
- mdgm-ntgrNETGEAR Employee Retired
Deb-B wrote: Thanks. Good to see the new version seems to be addressing everyone's queries. How long does Beta testing usually take?
Beta lengths can vary. Could be anything from a few weeks or so, to up to about 6 months. Most likely somewhere around a few months give or take a few weeks usually, I think. It does depend a bit on how big a firmware update is. This one appears to be a pretty big one.Deb-B wrote:
Also, can you recommend me any good sites where I can learn more about the general principles of FTP, uPnP, port forwarding etc. in general, as I am finding this level of technical discussion challenging and would like to learn more!
What do you want to know about those things? - Deb_BAspirantWhat the terms mean, what they do....
- StephenBGuru - Experienced UserThere is some basic information on networks here: http://compnetworking.about.com/od/basi ... basics.htm Though it is loaded with ads.
Once you get the basics down, wikipedia is helpful. - Deb_BAspirantWow, that's fantastic, exactly what I was after. Thanks!!! By the way, our Duo v2 makes lots of little clunky noises and the drives occasionally can be heard inside while it is not being used. The activity light also flashes occasionally. Is this normal?
