rubiks24
May 18, 2011Aspirant
ReadyNAS remote empty folder
I did some searching and I know this has been posted many times before, but I still cant get my setup to work after reading all the posts. When I click on "Connect to readynas ..." ReadyNAS remote sh...
rubiks24
May 24, 2011Aspirant
OlaJ wrote: I have a similar problem. I am running also 4.2.17 with ReadyNAS remote v1.0.9.60. However, I could connect from my mac, but can not get iPhone client to work. Installed t client on both my iphone and ipad. It says connected, and shows the user name. But I can not see the ReadyNAS name, which is supposed to be there according to guide.
Did you change the client version or the remote version on the nas?
Um thats really weird, well anyways, I removed the readynas remote addon, and downloaded the 1.0.9.51 version and now it works.
I think for the iphone app, you need to enable FTP or something. I read that somewhere but never got around to doing it. Good luck!
