rubiks24
May 18, 2011Aspirant
ReadyNAS remote empty folder
I did some searching and I know this has been posted many times before, but I still cant get my setup to work after reading all the posts. When I click on "Connect to readynas ..." ReadyNAS remote sh...
sonocronic
Jun 08, 2012Aspirant
The only thing I couldn't fix was this:
I have the “Ethernet adapter Leaf Networks Adapter” but its on ip: 5.173.249.135
And the instructions in the pdf doesn't solve it.
I set the ip to 5.0.0.3 as the instruction but when i turn ReadyNAS Remote on again it changes automaticly back to 5.173.249.135!
- If you see “Ethernet adapter Leaf Networks Adapter” but the IP address is not in the
range 5.168.0.0 – 5.168.255.255, then you need to manually configure the
adapter, please see http://www.readynas.com/download/remote ... dapter.pdf,
