rubiks24
May 19, 2011Aspirant
ReadyNAS remote empty folder
I did some searching and I know this has been posted many times before, but I still cant get my setup to work after reading all the posts. When I click on "Connect to readynas ..." ReadyNAS remote shares folder opens and remains blank.
Here is my setup:
SERVER SIDE:
ReadyNAS Ultra 4 running RAIDiator 4.2.17 with ReadyNAS remote v1.0.9.60 running connected to router and to internet. (Straight forward and simple)
The addon seems to be running fine, its green light stays lit, I have tried toggling it. I made sure that the user is added on the list. Removed it and re-added it.
*I did try to use the invite email, but I did not get any emails from any of my 3 email addresses, maybe that says something. Not sure because thats how one person fixed it.
Checked the settings, and Device ID is correct: NASNAME_MAC
No proxys and no ports.
Client Side:
Macbook Pro running ReadyNAS remote 1.0.21. Again no proxys or anything. Logs on fine, but again empty share folder.
I tried most suggestion, even reseting router and nas security to factory. Nothing seems to work.
Any suggestions? Maybe one of the mods can PM me and I can give access to my NAS box. Thanks in advanced guys!
Here is my setup:
SERVER SIDE:
Client Side:
- ReadySECUREApprenticecould you let us know how the issue was solved?
