profexorgeek
Sep 19, 2013Follower
ReadyNas Remote Leaf Network errors
I need assistance getting ReadyNas remote to work correctly on my laptop. The laptop is a Macbook Pro running Windows 7 Professional x64 via Bootcamp. Here is what I've done so far: I enabled R...
- Aug 12, 2015
Hello cbrien,
ReadyNAS Remote on Win10 needs a BETA version. See ReadyNAS Remote BETA for Windows
JennC
Aug 12, 2015NETGEAR Employee Retired
Hello profexorgeek,
Can you give us some screenshots during the installation?
Also when you ran the ReadyNAS Remote application, did you try right-clicking and choose Run as Administrator?
cbrien
Aug 12, 2015Initiate
That beta app did the trick. Thanks
