AnnoyedUser
Jan 30, 2017Tutor
ReadyNAS Remote Login Problems
Readynas Remote no longer recognizes assigned User ID's & passwords. We've been using a ReadyNAS Ultra 4 for the last 5 years wih both remote and local access. As of Friday, Jan 27, 2017 everythi...
- Feb 11, 2017
garrybunk wrote:My ReadyNAS Remote access is working this morning! I am getting an error message at Windows startup, something about a ReadyNAS Remote Config-Options file "can't access - file in use", but it's working so I just click ok and it disappears.
-Garry
Working for us as well. Required no actionon our part -- it simply started working.
Jan 31, 2017Guru - Experienced User
There seem to be a lot of issues with Windows systems reaching both readynas remote and readycloud over the past few days. It'd be helpful if someone from Netgear posted some info on what's going on.
AnnoyedUser
Jan 31, 2017Tutor
StephenB wrote:There seem to be a lot of issues with Windows systems reaching both readynas remote and readycloud over the past few days. It'd be helpful if someone from Netgear posted some info on what's going on.
Thanks. It's helpful to know that this is not isolated to our NAS.
How frequently do Netgear personnel participate in the forums?
