davidabroad
Nov 06, 2011Aspirant
ReadyNas Remote painfully slow!
I am running a ReadyNas Pro and have got ReadyNas Remote up and running from outside my home, but the speed is soooo slow it's almost unusable! Just wondering if I am doing something wrong with my se...
davidabroad
Hi and thanks for both replies.
I know that I have installed Raidar ...19
I have followed the troubleshooting guide as you suggest but most of it relates to no connection, not slow connection.
I dont see any message saying that I am being connected via a relay.
I have no gateway listed when I go to the Leaf Networks setup - so can't clear the gateway as suggested in the guide.
I also tried to replace the lnP2Padapter.dll as descibed in the Windows 7 troubleshooting guide but this causes the connection to totally fail with the message:
Initialization Failed
Unable to load lnP2Pnative.dll The specified procedure could not be found (Exception from HRESULT: 0x8007007F)
Can you suggest any way that I can find out if I am being connected via the Netgear Remote server rather than a direct connection?
Thanks for your support
David
David
