kevh
Jun 28, 2010Aspirant
Readynas Remote slow
just set up my Duo tested with remote today from work, i can see all shares but very slow copied file from Duo but a 35 meg file took about 20 mins the fasted speed reached was abot 50kbs is this norm...
claykin
Jun 30, 2010Aspirant
Need to know what your broadband speed (up/down) is on both ends of the connection to give you any advice. On a Duo you should get about 400Kb - 1Mb/s speeds using Remote if you have a direct connection (assuming your broadband can push these speeds). If your connection is relayed (due to firewall blocking) then your speeds will be 50Kb -100Kb/s.
