kevh
Jun 28, 2010Aspirant
Readynas Remote slow
just set up my Duo tested with remote today from work, i can see all shares but very slow copied file from Duo but a 35 meg file took about 20 mins the fasted speed reached was abot 50kbs is this norm...
claykin
Jul 01, 2010Aspirant
Yup, sounds like Remote is relaying your connection. Most likely due to firewall setup on one or both ends of your connection. If you PM cap1 he'll assist you in resolving it so Remote can connect directly.
