compact's avatar
compact
ReadyNAS Remote with Symantec Endpoint Protection arghhh
Hi
I have ReadyNas Duo with all the latest updates on Duo and PC.
It is a work PC and they've swapped to Symantec Endpoint Protection
From reading on here that is probably the reason why I cannot see it in Raidar or connect via ReadyNas Remote.
SO, what can I do?
I can't turn of Endpoint as it always restarts and I need admin access to change settings.
Does anyone know what specific settings I need to adjust to allow me to connect?
I might be able to find a Support Guy to make the changes unoffically.
All help, idea and tips welcome.
Thanks
1 Reply
  • Hello,
    You may need to contact your System admin and have them create an application exception for ReadyNas to function on your system. The computer security policy may be locking you down from running this app.
    http://www.symantec.com/business/support/index?page=content&id=HOWTO18254
    regards,
    Thomas
ProSupport for Business
