daweezels
Aug 19, 2020Aspirant
ReadyNAS RND4210 v3 - 1 WIn 10 Station cant connect , 4 others no problems
I have a customer that has 1 Station Win10 that sees the Nas under Network, mapped drives come up with Green but cant connect via mapped drives that have been setup up for a long time 2yrs+. They do ...
- Aug 20, 2020
aks-2 wrote:
You can use Windows Credential Manager to clear any passwords to the named network connection, which I think is what using teh IP address as an alternate "name" for the NAS is doing.
No. Some Windows PCs have trouble resolving the hostname of the NAS to the IP address - especially with the older NAS like the one here.
Though if the credentials aren't correct you can end up with access problems.
Sandshark
Aug 20, 2020Sensei
I have had a problem like that for some time when using the NAS name to map the shares. Try re-mapping using the IP address. Of course, for that to be a permanent solution, the IP address of the NAS must remain fixed. That is best done by address reservation in your router, not by static IP in the NAS.
Adding the NAS IP to the HOSTS file is another potential solution.
aks-2
Aug 20, 2020Apprentice
Worth checking what Win10 update is actually installed, just to be sure all the workstations are equal!
- StephenBAug 20, 2020Guru - Experienced User
- daweezelsAug 21, 2020Aspirant
Ok I tried it all. Finally I disconnected all mapped drives and redid them using \\ip\name, all came back. Even under Network the Nas drive now connects.(??) I'm not saying that all the fixes I did didnt take part in it but sometimes the simple answer just works. Thanks for all the help. Ive learned a few things along the way. Very greatfull for all the help!
