daweezels
Aug 19, 2020Aspirant
ReadyNAS RND4210 v3 - 1 WIn 10 Station cant connect , 4 others no problems
I have a customer that has 1 Station Win10 that sees the Nas under Network, mapped drives come up with Green but cant connect via mapped drives that have been setup up for a long time 2yrs+. They do ...
- Aug 20, 2020
aks-2 wrote:
You can use Windows Credential Manager to clear any passwords to the named network connection, which I think is what using teh IP address as an alternate "name" for the NAS is doing.
No. Some Windows PCs have trouble resolving the hostname of the NAS to the IP address - especially with the older NAS like the one here.
Though if the credentials aren't correct you can end up with access problems.
aks-2
Aug 20, 2020Apprentice
Worth checking what Win10 update is actually installed, just to be sure all the workstations are equal!
Aug 20, 2020Guru - Experienced User
