chaug
Dec 08, 2013Aspirant
ReadyNAS Ultra as seafile server
Hi! I'd like to use my ReadyNAS Ultra as a seafile server (see www.seafile.com) but this is not possible without some extra work, or perhaps it is not possible at all? This what this post is about. ...
chaug
Thanks! I have now installed python2.7, however, as I suspected, this was not the end of the trouble. I also need the following:
I was able to install python-simplejson with apt-get but when I try any of the other ones, I get an "unmet dependencies" error because the versions available via apt-get depend on lower versions of python. For example:
Is there any way to get around this?
- python-setuptools
- python-simplejson
- python-imaging
- python-mysqldb
The following packages have unmet dependencies:
python-setuptools: Depends: python (< 2.6) but 2.7.2-7 is to be installed
E: Broken packages
