chaug
Dec 08, 2013Aspirant
ReadyNAS Ultra as seafile server
Hi! I'd like to use my ReadyNAS Ultra as a seafile server (see www.seafile.com) but this is not possible without some extra work, or perhaps it is not possible at all? This what this post is about. ...
fastfwd
Dec 08, 2013Virtuoso
chaug wrote: I was able to install python-simplejson with apt-get but when I try any of the other ones, I get an "unmet dependencies" error because the versions available via apt-get depend on lower versions of python. For example: The following packages have unmet dependencies:
python-setuptools: Depends: python (< 2.6) but 2.7.2-7 is to be installed
E: Broken packages
Is there any way to get around this?
You can install setuptools manually:
cd ~
mkdir py_tmp
cd py_tmp
wget --no-check-certificate https://pypi.python.org/packages/source/s/setuptools/setuptools-2.0.tar.gz
tar -xvf setuptools-2.0.tar.gz
cd setuptools-2.0
python setup.py install
Then you can install PIP, which will make it easier to find and install python packages in the future:
cd ~/py_tmp
wget https://raw.github.com/pypa/pip/master/contrib/get-pip.py
python get-pip.py
The other two packages could be installed via pip -- i think "pip install PIL" and "pip install MySQL-Python" will get the right files -- but they'll want to be compiled by gcc-4.3, which probably isn't on your NAS... So you can try downloading and installing the Debian packages manually using dpkg instead. It'll be tedious and awkward, but maybe possible. Here's a python-imaging package that won't complain about python 2.7:
http://packages.debian.org/wheezy/python-imaging
and here's a python-mysqldb:
http://packages.debian.org/wheezy/python-mysqldb
I haven't checked, though, to see whether those packages will have other dependency problems.
