devilsrear
Apr 22, 2012Aspirant
Remote on Win7/Android
Hi I've gone through all the installation options, can connect on Android or windows 7 to Remote but not see anything. I've setup a "test" folder and can see it (read/write) to the folder via ft...
rc3675
Jul 19, 2012Aspirant
I'm running the client on Android 4.0.3 so can confirm that the app does work on ICS.
I also initially had problems though which were due to the fact I had set the Share access via FTP to be only for a specific user, rather than a default to everyone (for security reasons). If you are the sam,e then as well as setting FTP access under the Share option, you also need to go into the System option then set FTP Authentication Mode to User.
Does this help?
Does this help?
