BMach's avatar
BMach
Remote/Replicate is currently unreliable
Over the last few weeks, I have found that Replicate and Remote are unreliable.
Regularly Replicate will fail to run because either the source or the destination will not connect even though they are on the same LAN and both appear, with full information in the network window on Replicate.readynas.com (V1 Pro to NVX Business - both with 4.2.22 firmware and Replicate 1.1.5 and Remote 1.0.9.78.)
I also have problems with ReadyNAS Remote running from Windows 7 64 bit (Client 1.6.5.18). The client is happily running but the ReadyNAS devices (Pro and NVX) are said to be offline.
I also have limited if no success from either the New iPad or iPhone 4S (both on iOS 6.0) and running 1.3.7.
Replicate and Remote (both from PC and my iOS devices) used to work without fail. Now I cannot count on it working which means they are currently almost useless.
The only positive thing is that My Duo (v1) (firmware 4.1.10) running Remote 1.0.9.78 is at least online.
I thought there was a possibility the server end was down - but doubt this is the case as my Duo (v1) (firmware 4.1.10) running Remote 1.0.9.78 is at least online. I have to suspect that Replicate 1.1.5 and the Remote Client 1.6.5.18 are not as robust as they used to be.
Look forward to getting some reliability back into the system.
  • Oct 27th, just realized that this is what is causing all my headache lately and now my Readynas Pro4 is doing the same things mentioned above. Is there any fix to this yet? I have 2 Readynas Pro6's and 1 Readynas Pro4 doing the same thing.
    Cmon Netgear! Please get on these issues as you guys caused the issues. Very disappointed.
    Update!! I reinstalled replicate and remote to the newest version available. It seems to be working after a reboot of the box except for the ReadyDrop feature. I am ok with that as long as it replicates and I can get on the front view. It seems the shares are not letting me in through the 5.x.x.x address but it will let me in locally. PhotosII and Plex still works great.
    It has tons of potential and I hope Netgear is working on it. Please make it better as I do want my customers to have the best solution out there.
    Thanks
ProSupport for Business
