kennywan
Jan 20, 2016Aspirant
Replicate can't see volumes in devices #26347858
Hi,
Both my devices have been added to replicate but when trying to select backup data or backup system, i can't see volumes in either devices. I had a replicate job setup and it started failing back in 1/8/16, i removed from replicate and tried to add back to setup the job again. I tried upgrading readynas firmware and removing add-on but still having issues. Any suggestions?
- JennCNETGEAR Employee Retired
Hello kennywan,
Please let us know the model number of the NAS units and their current FW version. If you can post a screenshot, please do.
Did you also try another web browser? Are the 2 NAS units in the same network?
- kennywanAspirant
I have two ReadyNas 2100, one local and the other at our DR site. I upgraded both firmware to 4.2.28, replicate version 1.20.
I was using IE. I used Firefox and now can create the jobs and see the volumes. After I setup a system and back data job, i am getting the following error:
[2016-01-20 08:07:26] [Info] Replicate version: 1.2.0 build R1
[2016-01-20 08:07:26] [Info] Starting backup job "System Backup [2016-01-20 07h 59m AM]"
[2016-01-20 08:07:26] [Info] Locking target folder: /c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]
[2016-01-20 08:07:26] [Info] Resume folder is "/c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]/2016-01-20 08-01 (failed)/data"
[2016-01-20 08:07:27] [Info] p2p connect to viterbistorage1 in 9500056 network
[2016-01-20 08:07:27] [Error] Unable to connect to viterbistorage1
[2016-01-20 08:07:27] [Error] Connect error code: -501
[2016-01-20 08:07:27] [Error] Please check network connection between devices
[2016-01-20 08:07:27] [Info] Unlock target folder: /c/System Backup 2016-01-20/System Backup [2016-01-20 07h 59m AM]
[2016-01-20 08:07:27] [Info] Job finished
- kennywanAspirant
