TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- dcuellarAspirantI think I know what I'm doing wrong. I haven't installed "EnableRootSSh" yet.
- onicromAspirantStart Menu > Run Command > \\192.168.0.20\webroot\subsonic\
use notepad to edit subsonic.sh - dcuellarAspirantI got it guys, thank you.
- dcuellarAspirantI noticed that the checkbox for subsonic under "Installed add-ons" is not checked by default while the service is running. All of the other add-ons I have are though.
- yes that is a frontview issue, not necessarily a problem of the addon
- onicromAspirantis the latest subsonic (1.6) addon crashing for anyone else?
- super_poussinVirtuosotry increase memory usuable by subsonic
- whenever you upgrade, you have to re-change the memory amount in subsonic.sh
@ s-p is there a clean way of not over-writing a modified subsonic.sh or increasing the default max memory, or migrating an existing max memory setting when upgrading? - super_poussinVirtuosoyep I'm working on it for 1.8
