TeknoJnky
Sep 23, 2010Hero
[req] Subsonic
http://www.subsonic.org/pages/index.jsp
appears to be GPL/open source, music streamer.. similar/same as orb but looks much more flexible and open.
assuming its possible, would love to see this available for x86 devices to stream directly from nas
- dcuellarAspirantjetty-6.1.x, java 1.6.0_20, Linux (68.6 MB / 73.7 MB)
What does the MB data within the parenthesis mean? is that the memory??! If so, why is it only at 73.7 max? - because that is all that is being used at that particular time.
the memory setting you adjust is the 'max' memory, subsonic will use to that amount only if necessary. - dcuellarAspirantOk, and do you know if the java included is the latest?
dcuellar wrote: Ok, and do you know if the java included is the latest?
no idea, all i know is it currently works on my system, whether its the latest is irrelevant (to me).- dcuellarAspirantOk. Thanks anyway.
- super_poussinVirtuosoyou can optimize subsonic going in
cd /c/webroot/subsonic/jetty/1944/webapp/WEB-INF/classes
then edit
vi ehcache.xml
and replace
<cache name="musicFolderCache"
maxElementsInMemory="0"
eternal="true"
diskPersistent="true"
overflowToDisk="true"/>
with
maxElementsInMemory="1"
eternal="true"
1 is a minimum value
repeat this in all XXXX direcotories found in /c/webroot/subsonic/jetty/ - dcuellarAspirantWhat does this do?
I won't be able to do it now because my frontview is messing up on me. I was running into problems yesterday so I decided to delete subsonic 1.8 and try installing 1.6. Unfortunately something happened in that process that is not allowing me to install anything. All files are considered invalid. I can't even restart the machine from frontview anymore. - yuck.
I would ensure you have a complete backup of all data, and probably the simplist and easiest solution would be to factory default.
else, you could open an online ticket and get support looking into it. - super_poussinVirtuoso
dcuellar wrote: What does this do?
restart it with button on front panel - super_poussinVirtuoso
it's allow subsonic to use memory to cache data for albums in particular when indexing
