gibxxi
Nov 28, 2012Guide
[REQUEST] Maraschino UI (For XBMC)
Maraschino is a web style UI that runs on Python and can monitor multi-seat XBMC installs. It can also monitor SABNZBD, Sickbeard, CouchPotato and HeadPhones. Call it a central control panel for XBMC ...
gibxxi
Dec 27, 2012Guide
I got it running eventually. Would seem that the custom port setting as set in the config file is only read if the DB doesn't exist. If the DB does exist, it uses the port setting from that. Mine was still set to the default, so had to delete the DB and set it up again, then change the port in the DB before attempting any updates that trigger a restart.
- Aug 31, 2022Retired_Member
