timous
Oct 23, 2012Aspirant
[resolved] Subsonic started but port not listen
Hi,
I installed a Subsonic server on my ReadyNAS Duo v2, started on port 4040. Until this morning I had it perfectly working in local, but not remotely. After many tries I think I eventually found the error (my mistake, in the config file). But meanwhile, I may have broken something else: Subsonic doesn't work anymore. At all.
Actually, the service well started:
but port is not in the LISTEN state:
and of course, Subsonic is not reachable, even with an SSH port forwarding, since port is not listen:
Why can't I connect to this port?
Why service is well started but not using the port?
If it helps, this morning, when I was still a noob with iptables, I tried few experiments... but reboot is ok and I now have the following configuration back:
Thanks for helping!
root@Nas:~# ps aux | grep jav
root 11307 0.0 0.3 5276 760 pts/0 R+ 13:06 0:00 grep jav
root 15605 7.5 60.8 402544 150264 ? Sl Oct22 101:54 java -Xmx150m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
root@Nas:/var/subsonic# netstat -an | grep 4040
root@Nas:/var/subsonic# telnet localhost 4040
telnet: can't connect to remote host (127.0.0.1): Connection refused
root@Nas:/var/subsonic# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
LeafNetsIN all -- anywhere anywhere
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain LeafNetsIN (1 references)
Thanks for helping!
1 Reply
- timousAspirantOk, it seems that Subsonic just need 20 minutes on my ReadyNas Duo v2 to be completely started...
Solved. :(
