Mil24cb's avatar
Mil24cb
RND 2110 V1
Hi folks, just purchased a s/h NAT as in the title. I have the thing working, but when I click admin on the RAIDar, I get the following error in my browser:
This site can’t provide a secure connection
192.168.1.244 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
It seems I cannot access any settings but can see the disk on the network.
Can anyone please help?
  • StephenB's avatar
    You'll need to use an old browser - FireFox 94.0.2 will connect, as will the current version of internet explorer.  If you go with FireFox, make sure you immediately reconfigure it to turn off autoupdate.  Note you will get a certificate error (not the same as the SSL version mismatch), that you will need to click through.
    You can either stick with that solution, or you can edit virtual.conf as described here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
    • Mil24cb's avatar
      Mil24cb
      Hi Stephen, I don't suppose you know what I am doing wrong now?
      Tried a full factory default, seemed to work ok, but I cannot get passed the password stage...
      Tried Admin, password/1234 but it suggests credentials are wrong!
      Thanks again.
      • Sandshark's avatar
        Sandshark
        Sensei
        On units running version 4.x software, the default admin password is netgear1 unless is a very old version, in which case it's infrant1.
ProSupport for Business
