Silversurfer79
Feb 01, 2012Aspirant
RNWebGuard (Dansguardian) doesnt work
Hi Guys, So I’ve been looking a for a proxy/filter add-on for the web and I found RNWebGuard (Dansguardian) on the community add-on site. So purchased the add-on only to find it had a dependency (h...
Silversurfer79
Feb 02, 2012Aspirant
Works perfectly!
The link which references the "More..." ReadynasExtras doesn't resolve anything, I'm assume that's a holding page.
Thanks for the help, would should I do about RNWebGuard that I purchased?
Thanks again
The only thing is i cant customize it with the p.p as it doesn't load, not sure I may have been to hasty or if it need to build.Having said that its just started working after I enabled the proxy on my browser. I did a quick Google and found the default port 8118.
Thanks again
No content to show
