a_carneiro
Aug 05, 2012Tutor
SABNzbd - Specifying a LAN port
Hello guys I'm sorry if I missed this being discussed elsewhere, but here it goes. I have SABnzbd runnign on my ReadyNAS Ultra6 which, as you know, has two LAN ports. What I would like to do ...
gibxxi
Aug 12, 2012Guide
I have a similar issue, but I think the hassle of having two sets of phone lines would cost you more than you'd gain, especially with BT's installation charges and line rental. Would it not be easier to limit SABnzbd+ download speed? SABnzbd+ will utilize all the available bandwidth if you don't limit it, slowing down regular browsing, so in my case I set a download limit of 500KBps (Max rate for me is about 700-750KBps) which still allows me to do regular browsing.
The setting in SABnzbd+ is: Config -> General -> Download Speed Limit.
