sshambar2
Sep 16, 2020Star
Samba 3.6.25 build for ReadyNAS NV+ v2
My brother was having difficulties connecting to his ReadyNAS from his work laptop running Win10, and asked if I could enable SMB2 on his NAS (he couldn't install SMB1 compatibility as the laptop is ...
sshambar2
Dec 06, 2020Star
Yes, I had my brother install it on his NV+ v2 and it replaced the (currently) installed addon with the new version.
Of course, it's also possible to just remove the old version and install the new one :)
S.
treboR2Robert
Dec 06, 2020Aspirant
Hi Scott,
Thanks for updating the addon.
Will installing the new one actually do anything for me ? as mine is obviously now working after what we done the other day.
I am thinking of doing a OS Reinstal anyway as I would like to disable SSH and I don't think there is a way to do that apart from a OS Reinstall or a Factory Reset.
One thing I have noticed when using SMB at the moment is that I can't access my shares if I log in as a user. I have all the correct permissions set up (at least I think so) but no matter what I do, and I have tried A LOT of different things, it will not let me access the shares as a user, it only works if I login using the admin account that I use to access the Web Interface.
I don't know if this worked with the standard SMB1 setup ?
I will have a play this week at some point when I get a chance and report back.
Thanks again :smileyhappy:
- sshambar2Dec 10, 2020Star
Reinstalling the addon will make it so that uninstalling the addon correctly restores the old samba binaries (by re-running the ldconfig on removal)... so you might consider it if you ever think you might remove the addon :)
If you want to disable ssh, that's pretty easy without reinstalling... run the following (as root)
sed -i s/SSH=1/SSH=0/ /etc/default/services
/etc/init.d/ssh stop
I'll have my brother test logging in as non-admin, and see if that works for him.
- treboR2RobertDec 10, 2020Aspirant
Hi mate,
I had a chance last night / today to do a factory reset.
Once reset I tried logging in with the standard smb1 setup and I was having the same problem. After a few hours of pulling my hair out it turned out to be something very simple.
I was trying to access the shares by mapping a network drive in windows 10.
\\xxx.xxx.x.x\c\media
Logging in as admin works fine like this but as a user it says NO !
\\xxx.xxx.x.x\media
It turns out that if I leave the "c" out then I can login as a user no problem :smileylol: :smileyfrustrated:
I'm assuming it has something to do with the fact that only the admin can access \\xxx.xxx.x.x\c but it still doesn't make much sense to me. :smileyindifferent:
Anyway I got everthing setup how I wanted and I then disconneced the mapped drives, disabled SMB1 on my computer and rebooted it.
I installed the new version of your addon and like magic windows connected to it 1st time (without the "c" of course :smileylol:) :smileyvery-happy: I didn't even have to turn SMB off and on in the web interface.
GREAT work Sir !!!
Thank you very much, I (and I guess a fair few others) really appreciate it !
:robotvery-happy:
That's insteresting that you can disable ssh ( I assume you do this over ssh )
So what happens after you type that command ? Does the ssh session your in just get cut off / disconnected ?
I done a factory reset anyway now so don't need it but thanks for the instructions. :smileyhappy:
- StephenBDec 10, 2020Guru - Experienced User
Whether it makes sense to you or not, it is precisely because only the admin can access \\xxx.xxx.x.x\c
There are both network permissions and file permissions involved in access controls. The C share is set up so that only the admin has the needed network permissions to access it.
treboR2Robert wrote:So what happens after you type that command ? Does the ssh session your in just get cut off / disconnected ?
No, the command stops the sshd daemon (and disables it starting at boot) which prevents new sessions from connecting, but the current session will continue until you log out.
- StephenBDec 11, 2020Guru - Experienced User
Personally I'd leave ssh enabled, especially on a legacy NAS (where there are no support implications).
- treboR2RobertDec 11, 2020Aspirant
It makes sense that only admin can access c yes.
What doesnt make sense is \\xxx.xxx.x.x\media is NOT the path of media the path of media is \c\media.
When I type \c\media I am trying to access media NOT c
Whether it makes sense to you or whether it makes sense to me doesn't matter as you said.
Thanks for the comment though.
sshambar2 OK I see what you mean now with the ssh daemon, thanks for explaining, it makes sense.
StephenBThanks for the advice about leaving ssh enabled, but I'm hoping there is nothing else I need to do via ssh now, the unit is just going to used as a backup for my TrueNAS server.
My thinking is why leave something enabled that could "potentially" be a security risk. I could be wrong (I usually am). Anyway if there is something else I need to do via ssh I can always enable it again. Is there something you reccomend doing via ssh ?
It is useful for some troubleshooting/fixes. For instance if the OS partition gets full.
But generally when you need it for that, you can't enable it - because the Web UI isn't working properly. So I just leave it enabled on my ReadyNAS. Port 22 isn't exposed to the internet, so the only security risks are on my local LAN.
- SandsharkDec 11, 2020Sensei
treboR2Robert wrote:It makes sense that only admin can access c yes.
\\xxx.xxx.x.x\media isn't the full Linux path, but it is the share name. It's done that way so everybody doesn't need access to C.
Yes. Network access to any UNC that starts with \\xxx.xxx.x.x\c requires access to to c share. That is the way SMB network shares work.
sshambar2 wrote:If you want to disable ssh, that's pretty easy without reinstalling... run the following (as root)
And then you can turn it back on again by re-loading the add-on?
The SSH add-on for OS4.x is a toggle, and is called that. The one for OS5.x is just called an enable, but might also toggle. I've never tried.
Sandshark wrote:
The SSH add-on for OS4.x is a toggle, and is called that. The one for OS5.x is just called an enable, but might also toggle. I've never tried.I saw this too that for OS4.x the addon is a toggle to turn ssh on and off.
Unfortunately the addon for OS5.x is only for enabling ssh. I actually tried installing it for a 2nd time (to try and disable ssh) and it did nothing, it just said addon installed succesfully and ssh was still enabled.
StephenB wrote:Yes. Network access to any UNC that starts with \\xxx.xxx.x.x\c requires access to to c share. That is the way SMB network shares work.
Makes sense if you know i guess.
I probably did know at some point and forgot.
And I will probably forget next time too :smileylol:
StephenB wrote:It is useful for some troubleshooting/fixes. For instance if the OS partition gets full.
I see your reasoning.
Hopefully mine will be ok though as I am only using the system as a backup for my TrueNAS and 99% of the time it will be off and just get powered on by schedule for backups.
The only service running will be rysnc and https. (SMB I will turn on and off as I need it)
Getting TrueNAS to rsync directly to the ReadyNAS the other day took me AGES to fugure out :smileyfrustrated:
I am in two minds at the moment though whether to leave the ReadyNAS at my mums house and try and get the TrueNAS at my house to rsync over ssh so that the backup is "off site".
I think it may be a little over my head though to get that working securely.
- StephenBDec 12, 2020Guru - Experienced User
The only file sharing protocol I enable on my own backup NAS is rsync. Though as I said, I do have ssh enabled on them.
If you disable ssh, then you can still gain access through tech support mode. Though I haven't gone through the steps needed to mount the OS partition and data volume(s) on the v2 (since I don't own that model).
And of course if the ReadyNAS does run into trouble, you can factory default and run the backups again (as long as the TrueNAS remains healthy).
...try and get the TrueNAS at my house to rsync over ssh so that the backup is "off site".
I don't believe your ReadyNAS model has built-in support for rsync over ssh - if I'm correct on that, it would be tricky to get this to work.
- treboR2RobertDec 12, 2020Aspirant
StephenB wrote:
treboR2Robert wrote:...try and get the TrueNAS at my house to rsync over ssh so that the backup is "off site".
I have been doing a bit of research and I think I may have found a way to make it work (maybe) :smileyindifferent:
At home I have a Asus Router running Asuswrt-Merlin with a OpenVPN server.
At my mums I have another Asus Router running Merlin LTS.
I had a "quick" read online and it seems I may be able to set the Router at my mums house to use OpenVPN as a client, BUT only for the ReadyNAS ( so all other devices at my mums wouldn't use the VPN)
I am thinking that this will mean that the ReadyNAS (at my mums) and the TrueNAS (at my house) will think they are on the same network and I can just do normal Rsync betwwen them.
Got some other stuff to do over the weekend so I'll do a bit more research if I get a minute and then I'll try it out next week and report back here incase anyone else wants to do it.
Since the NV+ v2 hasn't gotten security updates in some years, I think that it's better to use a VPN connection for this than to use rsync-over-ssh.
