traumspiel
Oct 21, 2009Aspirant
Samba v3.3.7 addon as a domain controller
Hello
I want Create with the Samba v3.3.7 addon on my NV+ a domain controller,
I do not yet know me with samba, unfortunately.
I would be happy if you can help me.
In my network ar 8 machine with XP64 and win7 and
i need to be 5 users.
Thanks already in advance,
Steffen
Steffen
- airwoflAspirantHi,
First of all, make sure the registry keys below have been applied to the Windows 7 hosts before joining them to the domain. You will get trust relationship issues if you don't and will need a local admin account to fix them.HKLM\System\CurrentControlSet\Services\LanmanWorkstation\Parameters
DWORD DomainCompatibilityMode = 1
DWORD DNSNameResolutionRequired = 0
1. Make sure you do not have a system elevated to master browser / domain controller status on a network for the domain you want to host on the ReadyNAS. Otherwise, this will not work.
2. You will need to have root SSH access via the official addon if you haven't installed it already - read the notes about support though if you have not.
3. Backup your /etc/samba/smb.conf file first, in case it goes wrong.
4. Make sure that within FrontView that the Security Mode is set to User and the Workgroup is the name of the Domain you would like to host for.
5. Create a group within FrontView to contain your domain admin users. At a minimum, it needs to have the user admin in it.
6. Edit /etc/samba/smb.conf and make the below exists within the [global] section. To be honest, it's been a while and I can't remember which exact pieces I needed to add versus modify. Also note there are parameters that need updating so please read the below.add machine script = "/usr/sbin/useradd -s /bin/false -d /dev/null %u"
admin users = @<name of the group you created through FrontView to be your Domain Admins>
domain logons = 1
domain master = 1
encrypt passwords = 1
local master = 1
logon drive = <the drive letter you want the home drive to be - mine is H:>
logon home = \\%L\%U
logon path = \\%L\profiles\%U
logon script = logon.bat
netbios name = %h
os level = 33
passdb backend = smbpasswd
passwd chat = "*New password:*" %n\r "*New password (again):*" %n\r \ "*Password changed*"
passwd program = "/usr/bin/passwd %u"
preferred master = 1
printer admin = @<name of the group you created through FrontView to be your Domain Admins>
template homedir = /c/home/%U
time server = 1
wins support = 1
7. Restart Samba by running /etc/init.d/samba restart
The above will also give you Roaming profiles so you may need to set Group Policies on the hosts to redirect roaming profile directories to local ones if the profiles end up being large and slow to logon / logoff. - jastronomyAspirantI recommend stopping at step 6; and doing the following:
;additional line here to call the next fileinclude = /etc/Mods/domainsmb.conf
Next; from the SSH session; type in the following:
MKDIR /etc/Mods
NEXT;
vi /etc/Mods/domainsmb.conf
paste the following code inside the window:# This file was written to setup the ReadyNAS DUO as a PDC Server.
[global]
netbios name = ReadyNAS
server string = Samba %v on %L
workgroup = ReadyNAS
; domain & local master browser
; coz we're dealing with Win2k
os level = 65
prefered master = yes
domain master = yes
local master = yes
domain logons = yes
; misc options
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=8192 SO_RCVBUF=8192
time server = yes
; do not show files starting with dots
hide dot files = yes
; Central European code page support
client code page = 852
character set = ISO8859-2
; do not allow guest access, use only local system accounts
security = user
guest ok = no
invalid users = bin deamon sys man postfix mail ftp
admin users = @Domain.Admins, root
; domain administrators
domain admin group = @Domain.Admins, root
domain admin users = @Domain.Users, root admin
; use encrypted passwords
encrypt passwords = yes
; logging (max log size is in kB)
log level = 2
log file = /var/log/samba/log.%L
max log size = 1000
debug timestamp = yes
syslog = 1
; user roaming profiles path
logon path = \\%N\profiles\%u
; general logon script (in DOS format)
logon script = logon.vbs
; share for storing user profiles
; although it's probably easier to use the "\\%N\%u" share... just not sure how
[profiles]
path = /home/samba/profiles
writeable = yes
create mask = 0700
directory mask = 0700
browsable = no
#share for domain controller
[netlogon]
comment = "Domain Logon Share"
path = /home/samba/netlogon
public = yes
writeable = no
browsable = yes
admin users = root @Domain.Admins
valid users = root @Domain.Users
And next; in the SSH window, hit ESC, then type :wq!
That will effectively save your own DOMAIN config file; and include that in the SAMBA default config file (easier to comment out the include line isn't it?).
I did this about 4 minutes ago; but the changes to the /etc/samba/smb.conf file won't take place if the samba service is running.
so stop it before making any changes.
invoke-rc.d samba stop - do this right at the start
invoke-rc.d samba start - when finished, do this - jastronomyAspirantoops forgot; from the Frontview webpage; add two groups "Domain.Users" and "Domain.Admins"... sure you can all work that bit out :P
- HeimchenAspirantHi,
I folled these steps and tried to add my Win7 PC to the domain. ut it doesn't work. What do I have to do to add a PC to the domain? - quickly_nowApprenticeProblems... problems...
RAIDiator 4.2.17 includes Samba 3.5.8...
When you make edits to the smb.conf file - the next reboot sees your edits automagically removed.
Using the information here, a windows XP machine can't join the domain.
Still working through what to do to make it work - so far I've blown about 8 hours on this with little progress. Much frustration. - nbl1268AspirantHi Jastronomy,
Just looking over the details Airwolf and you have provided here for setting up Samba as DC.
When you say stop at step 6, are you saying stop before or after step 6?
The additional line you have showninclude = /etc/Mods/domainsmb.conf
i'm assuming is entered via the SSH session?
Likewise is the code to be pasted (that you have listed after the vi command) done in the ssh session?
After all of this, is step 7 still needed?
Lastly, how much of this is applicable if you do not use the Samba 3.3.7 addon, eg just use the SAMBA version in RAIDiator 4.1.8?
Thanks
Neil
