Anonymous
Dec 17, 2016Setting proxy server on ReadyNAS...Possible?
Hi I am using transmission on my ReadyNAS duo v2 and I wanted to know if I can use a proxy server on my readynas. I am trying to use some torrent sites which are blocked via my ISP but can ...
sotrack
Dec 19, 2016Luminary
I do not understand how proxy server will help you bypass IPS.
Your path before setup proxy server:
transmission -> IPS -> tracker or P2P connection
Your path after setup proxy server:
transmission -> proxy server -> IPS -> tracker or P2P connection
The IPS will see your traffic after proxy server.
- StephenBDec 19, 2016Guru - Experienced User
Something along these lines I think: https://nordvpn.com/tutorials/socks5/utorrent/
- sotrackDec 19, 2016Luminary
VPN is clear approach if something exists after IPS for trafic decryption (like nordvpn.com). And proxy is not required here just VPN channel from NAS/router to nordvpn.com
The proxy is not required, but clearly it is a connection method that nordvpn provides for their customers.
I agree that a vpn is better suited to the purpose, since socks5 is not encrypted. But a socks5 proxy could still serve as an ISP bypass if the ISP packet inspection doesn't look past the SOCKS encapsulation.
