Anonymous
Dec 17, 2016Setting proxy server on ReadyNAS...Possible?
Hi I am using transmission on my ReadyNAS duo v2 and I wanted to know if I can use a proxy server on my readynas. I am trying to use some torrent sites which are blocked via my ISP but can ...
Dec 19, 2016Guru - Experienced User
Something along these lines I think: https://nordvpn.com/tutorials/socks5/utorrent/
sotrack wrote:
I do not understand how proxy server will help you bypass IPS.
sotrack
Dec 19, 2016Luminary
VPN is clear approach if something exists after IPS for trafic decryption (like nordvpn.com). And proxy is not required here just VPN channel from NAS/router to nordvpn.com
- StephenBDec 19, 2016Guru - Experienced User
The proxy is not required, but clearly it is a connection method that nordvpn provides for their customers.
I agree that a vpn is better suited to the purpose, since socks5 is not encrypted. But a socks5 proxy could still serve as an ISP bypass if the ISP packet inspection doesn't look past the SOCKS encapsulation.
