dbott67
Nov 17, 2011Guide
[Solved] No add-on packages are currently available
EDIT: Solved via OS re-install from boot menu. After factory resetting the unit, I restored an old config from a firmware version prior to 4.2.16 which caused grief with some of the .conf files. I'...
WhoCares_
Nov 17, 2011Mentor
The available add-ons section is filled dynamically by quering a web service. So chances are your NAS either doesn't talk to the interthingy or that the other side of the communication link is down ;)
-Stefan
-Stefan
