dbott67
Nov 17, 2011Guide
[Solved] No add-on packages are currently available
EDIT: Solved via OS re-install from boot menu. After factory resetting the unit, I restored an old config from a firmware version prior to 4.2.16 which caused grief with some of the .conf files. I'...
dbott67
Nov 17, 2011Guide
Hmmm... Prosey talks to the interthingy.
APT-GET also works, as I used it to install nano (although I'm getting the GPG error below on both my Pro and NVX):
I ran netstat, but I don't know what the service is, so I don't really know what I'm looking for:
Prometheus:~# ping www.netgear.com
PING netgear.com (64.94.70.219) 56(84) bytes of data.
64 bytes from ntgr.co.in (64.94.70.219): icmp_seq=1 ttl=237 time=83.3 ms
64 bytes from ntgr.co.in (64.94.70.219): icmp_seq=2 ttl=237 time=87.4 ms
64 bytes from ntgr.co.in (64.94.70.219): icmp_seq=3 ttl=237 time=87.8 ms
64 bytes from ntgr.co.in (64.94.70.219): icmp_seq=4 ttl=237 time=86.8 ms
--- netgear.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3002ms
rtt min/avg/max/mdev = 83.350/86.362/87.801/1.772 ms
Prometheus:~# apt-get update
Get:1 http://www.readynas.com 4.2.19/ Release.gpg [490B]
Get:2 http://archive.debian.org etch Release.gpg [1033B]
Hit http://www.readynas.com 4.2.19/ Release
Err http://www.readynas.com 4.2.19/ Release
Hit http://archive.debian.org etch Release
Get:3 http://www.readynas.com 4.2.19/ Release [738B]
Ign http://www.readynas.com 4.2.19/ Release
Ign http://archive.debian.org etch/main Packages/DiffIndex
Hit http://archive.debian.org etch/main Packages
Ign http://www.readynas.com 4.2.19/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.19/ Packages
Fetched 1229B in 1s (943B/s)
Reading package lists... Done
W: GPG error: http://www.readynas.com 4.2.19/ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B7F02108D553259A
W: You may want to run apt-get update to correct these problems
Prometheus:~# netstat -a -p
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 *:44992 *:* LISTEN 2313/rpc.mountd
tcp 0 0 *:34113 *:* LISTEN -
tcp 0 0 *:nfs *:* LISTEN -
tcp 0 0 *:nut *:* LISTEN 3184/upsd
tcp 0 0 *:daap *:* LISTEN 2917/mt-daapd
tcp 0 0 *:rsync *:* LISTEN 2912/rsync
tcp 0 0 *:mysql *:* LISTEN 2056/mysqld
tcp 0 0 *:netbios-ssn *:* LISTEN 22633/smbd
tcp 0 0 *:684 *:* LISTEN 2216/rpc.rquotad
tcp 0 0 *:sunrpc *:* LISTEN 2026/portmap
tcp 0 0 *:www *:* LISTEN 6829/apache-ssl
tcp 0 0 *:51413 *:* LISTEN 24655/transmission-
tcp 0 0 *:8181 *:* LISTEN 24655/transmission-
tcp 0 0 *:8086 *:* LISTEN 6829/apache-ssl
tcp 0 0 *:ipp *:* LISTEN 2101/cupsd
tcp 0 0 *:https *:* LISTEN 6829/apache-ssl
tcp 0 0 *:microsoft-ds *:* LISTEN 22633/smbd
tcp 0 0 *:32765 *:* LISTEN 2254/rpc.statd
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49775 ESTABLISHED8299/apache-ssl
tcp 0 0 localhost.localdoma:nut localhost.localdo:46684 ESTABLISHED3184/upsd
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49779 ESTABLISHED6829/apache-ssl
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49777 ESTABLISHED8303/apache-ssl
tcp 0 0 localhost.localdo:46684 localhost.localdoma:nut ESTABLISHED3196/upsmon
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49773 ESTABLISHED8178/apache-ssl
tcp 0 0 Prometheus.bott.c:39336 photos.readynas.com:www TIME_WAIT -
tcp 0 0 Prometheus:microsoft-ds 192.168.1.199:51035 ESTABLISHED22823/smbd
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49783 ESTABLISHED8304/apache-ssl
tcp 0 0 Prometheus.bott.ca:www 217-162-227-180.d:49781 ESTABLISHED8302/apache-ssl
tcp6 0 0 *:rsync *:* LISTEN 2912/rsync
tcp6 0 0 *:51413 *:* LISTEN 24655/transmission-
tcp6 0 0 *:ftp *:* LISTEN 2641/proftpd: (acce
tcp6 0 0 *:ssh *:* LISTEN 1912/sshd
tcp6 0 244 Prometheus.bott.ca:ssh ::ffff:192.168.1.:49581 ESTABLISHED5957/1
udp 0 0 *:nfs *:* -
udp 0 0 Prometheus.bott.c:22081 *:* 1869/raidard
udp 0 0 *:22081 *:* 1869/raidard
udp 0 0 *:54367 *:* 22782/avahi-daemon:
udp 0 0 *:sunrpc *:* 2026/portmap
udp 0 0 192.168.1.25:netbios-ns *:* 22630/nmbd
udp 0 0 Prometheus.b:netbios-ns *:* 22630/nmbd
udp 0 0 *:netbios-ns *:* 22630/nmbd
udp 0 0 192.168.1.2:netbios-dgm *:* 22630/nmbd
udp 0 0 Prometheus.:netbios-dgm *:* 22630/nmbd
udp 0 0 *:netbios-dgm *:* 22630/nmbd
udp 0 0 *:51863 *:* 2313/rpc.mountd
udp 0 0 *:683 *:* 2216/rpc.rquotad
udp 0 0 *:42689 *:* 24655/transmission-
udp 0 0 *:51413 *:* 24655/transmission-
udp 0 0 *:734 *:* 2254/rpc.statd
udp 0 0 *:mdns *:* 22782/avahi-daemon:
udp 0 0 *:60693 *:* -
udp 0 0 Prometheus.bott.c:57769 192.168.1.1:5351 ESTABLISHED24655/transmission-
udp 0 0 *:32765 *:* 2254/rpc.statd
udp6 0 0 *:59451 *:* 22782/avahi-daemon:
udp6 0 0 *:mdns *:* 22782/avahi-daemon:
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] STREAM LISTENING 847 1863/acpid /var/run/acpid.socket
unix 2 [ ACC ] STREAM LISTENING 5724 3160/usbhid-ups /var/run/nut/usbhid-ups-UPS
unix 2 [ ACC ] STREAM LISTENING 743948 22782/avahi-daemon: /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 81639 2056/mysqld /var/run/mysqld/mysqld.sock
unix 2 [ ] DGRAM 95 909/udevd @/org/kernel/udev/udevd
unix 2 [ ACC ] STREAM LISTENING 3445 2641/proftpd: (acce /var/run/proftpd.sock
unix 2 [ ACC ] STREAM LISTENING 3130 2107/dbus-daemon /var/run/dbus/system_bus_socket
unix 2 [ ACC ] STREAM LISTENING 1015635 2641/proftpd: (acce /var/run/proftpd.sock
unix 13 [ ] DGRAM 1014 2071/syslogd /dev/log
unix 2 [ ] DGRAM 752828 24655/transmission-
unix 3 [ ] STREAM CONNECTED 751731 24655/transmission-
unix 3 [ ] STREAM CONNECTED 751730 24655/transmission-
unix 3 [ ] STREAM CONNECTED 751729 24655/transmission-
unix 3 [ ] STREAM CONNECTED 751728 24655/transmission-
unix 2 [ ] DGRAM 744030 22823/smbd
unix 3 [ ] STREAM CONNECTED 742598 2107/dbus-daemon /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 743949 22782/avahi-daemon:
unix 2 [ ] DGRAM 743945 22782/avahi-daemon:
unix 3 [ ] STREAM CONNECTED 4970 3160/usbhid-ups /var/run/nut/usbhid-ups-UPS
unix 3 [ ] STREAM CONNECTED 5750 3184/upsd
unix 2 [ ] DGRAM 5745 3184/upsd
unix 2 [ ] DGRAM 5718 3160/usbhid-ups
unix 2 [ ] DGRAM 4621 2912/rsync
unix 2 [ ] DGRAM 3927 2616/ifplugd
unix 2 [ ] DGRAM 3922 2613/ifplugd
unix 2 [ ] DGRAM 3917 2610/ifplugd
unix 2 [ ] DGRAM 3327 2254/rpc.statd
unix 3 [ ] STREAM CONNECTED 2906 2107/dbus-daemon
unix 3 [ ] STREAM CONNECTED 2905 2107/dbus-daemon
unix 2 [ ] DGRAM 2893 2087/klogd
