dbott67
Nov 17, 2011Guide
[Solved] No add-on packages are currently available
EDIT: Solved via OS re-install from boot menu. After factory resetting the unit, I restored an old config from a firmware version prior to 4.2.16 which caused grief with some of the .conf files. I'...
WhoCares_
Nov 17, 2011Mentor
What do you get when you call
from your browser?
-Stefan
https://ip.of.readynas/addon?command=getAvailableAddons
from your browser?
-Stefan
