dbott67
Nov 17, 2011Guide
[Solved] No add-on packages are currently available
EDIT: Solved via OS re-install from boot menu. After factory resetting the unit, I restored an old config from a firmware version prior to 4.2.16 which caused grief with some of the .conf files. I'...
dbott67
Nov 17, 2011Guide
WhoCares? wrote: What do you get when you call https://ip.of.readynas/addon?command=getAvailableAddons
from your browser?
-Stefan
Not Found
The requested URL /addon was not found on this server.
My NVX is still running an older version of RAIDiator (4.2.13). It's next on the list to get upgraded and factory defaulted.
FWIW, ReadyNAS Photos II is working on the Pro, as is my Wordpress blog (thanks to your PHP :) ) and Transmission (thanks to SP).
