dbott67
Nov 17, 2011Guide
[Solved] No add-on packages are currently available
EDIT: Solved via OS re-install from boot menu. After factory resetting the unit, I restored an old config from a firmware version prior to 4.2.16 which caused grief with some of the .conf files. I'...
mdgm-ntgr
Nov 18, 2011NETGEAR Employee Retired
I would try temporarily commenting out the last line I quoted in my post above and restarting apache. This might tell if an add-on is causing a problem with apache.
You might also want to take a look at /var/log/frontview/error.log
