handy1
Mar 04, 2013Aspirant
[SOLVED] NTP-Server & Firewall port settings:
I need a little help with this one please? I've been using the NTP-Server add-on on my Duo v.1. for many months now. It serves my Linux boxes beautifully. Anyway, the problem(?): I just modi...
handy1
Mar 07, 2013Aspirant
Following is without the firewall running:
[handy@jarmano ~]$ sudo netstat -tulpn
[sudo] password for handy:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 398/rpcbind
tcp 0 0 0.0.0.0:37872 0.0.0.0:* LISTEN 421/rpc.statd
tcp 0 0 0.0.0.0:58359 0.0.0.0:* LISTEN 422/rpc.statd
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 360/cupsd
tcp 0 0 0.0.0.0:58904 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:52026 0.0.0.0:* LISTEN 425/rpc.statd
tcp6 0 0 :::41386 :::* LISTEN 425/rpc.statd
tcp6 0 0 :::111 :::* LISTEN 398/rpcbind
tcp6 0 0 :::52627 :::* LISTEN -
tcp6 0 0 :::33524 :::* LISTEN 421/rpc.statd
tcp6 0 0 ::1:631 :::* LISTEN 360/cupsd
tcp6 0 0 :::45277 :::* LISTEN 422/rpc.statd
udp 0 0 0.0.0.0:68 0.0.0.0:* 413/dhclient
udp 0 0 0.0.0.0:111 0.0.0.0:* 398/rpcbind
udp 0 0 192.168.1.4:123 0.0.0.0:* 412/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 412/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 412/ntpd
udp 0 0 127.0.0.1:601 0.0.0.0:* 425/rpc.statd
udp 0 0 0.0.0.0:60222 0.0.0.0:* -
udp 0 0 0.0.0.0:982 0.0.0.0:* 398/rpcbind
udp 0 0 127.0.0.1:1021 0.0.0.0:* 421/rpc.statd
udp 0 0 127.0.0.1:1022 0.0.0.0:* 422/rpc.statd
udp 0 0 0.0.0.0:52292 0.0.0.0:* 425/rpc.statd
udp 0 0 0.0.0.0:40166 0.0.0.0:* 422/rpc.statd
udp 0 0 0.0.0.0:61162 0.0.0.0:* 413/dhclient
udp 0 0 0.0.0.0:51055 0.0.0.0:* 421/rpc.statd
udp6 0 0 :::111 :::* 398/rpcbind
udp6 0 0 fe80::fad1:11ff:fe0:123 :::* 412/ntpd
udp6 0 0 ::1:123 :::* 412/ntpd
udp6 0 0 :::123 :::* 412/ntpd
udp6 0 0 :::47533 :::* 413/dhclient
udp6 0 0 :::43513 :::* 425/rpc.statd
udp6 0 0 :::59956 :::* 421/rpc.statd
udp6 0 0 :::982 :::* 398/rpcbind
udp6 0 0 :::44073 :::* 422/rpc.statd
udp6 0 0 :::58923 :::* -
[handy@jarmano ~]$
