handy1
Mar 04, 2013Aspirant
[SOLVED] NTP-Server & Firewall port settings:
I need a little help with this one please? I've been using the NTP-Server add-on on my Duo v.1. for many months now. It serves my Linux boxes beautifully. Anyway, the problem(?): I just modi...
handy1
Mar 08, 2013Aspirant
I made the firewall settings such that the ntp service is using the UDP protocol for both IN & OUT & now I get the following which is certainly an improvement, as at least now the delay, offset & jitter numbers look to be behaving as they should (instead of all being zero). But now I've got this:
when I use my time alias - the command follows:
Here is the output from the above alias:
I still have the 90 second delay on boot too...
NTP synchronized: no
RTC in local TZ: no
alias time='timedatectl status && ntpq -c lpeer'
[handy@jarmano ~]$ time
Local time: Fri 2013-03-08 19:28:45 EST
Universal time: Fri 2013-03-08 08:28:45 UTC
RTC time: Fri 2013-03-08 08:28:46
Timezone: Australia/Sydney (EST, +1100)
NTP enabled: yes
RTC in local TZ: no
DST active: yes
Last DST change: DST began at
Sun 2012-10-07 01:59:59 EST
Sun 2012-10-07 03:00:00 EST
Next DST change: DST ends (the clock jumps one hour backwards) at
Sun 2013-04-07 02:59:59 EST
Sun 2013-04-07 02:00:00 EST
remote refid st t when poll reach delay offset jitter
*192.168.1.15 83.170.1.42 3 u 52 64 1 0.465 7.278 6.586
