handy1
Mar 04, 2013Aspirant
[SOLVED] NTP-Server & Firewall port settings:
I need a little help with this one please? I've been using the NTP-Server add-on on my Duo v.1. for many months now. It serves my Linux boxes beautifully. Anyway, the problem(?): I just modi...
Mar 08, 2013Guru - Experienced User
I don't think the added incoming rules are needed for NTP (which AFAIK only needs UDP port 123). I suspect its the "allow ntp" command that is solving the problem (assuming the 90 second start up issue was all because of NTP, and not due to some other services).
Anyway, I'm glad its sorted out. Thx for sharing your solution.
