Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 29, 2011Aspirant
super-poussin wrote: can you download it again and install it again ? if problem persist can you try
http://192.168.1.2/nasmon/install/install.php
Seems like loadavg bug:
http://sourceforge.net/tracker/?func=de ... id=1102212
Almost got it working, will try your new version also.
config.xml.php is the culprit:
$data .= "<setting name='secure_conn' value='on'></setting>";
That line is missing, so loadvg doesnt use https, its partial fix though. Graph page works, but others try still use http instead of https.
And my best guess is, that your x86 version should also be affected from this... :?
EDIT: Still same, only works if I apply that manual fix, mentioned above... :roll:
Also another line needs to be modified, or it will not work:
$data .= "<setting name='allow_anyone' value='on'></setting>";
(default is off, and then it still goes to https/http loop)
EDIT v2: Also I guess phpsysinfo needs to be updated to 3.0.10, because DUO doesnt have "horsepower" to compress that amount of data and it times out and never loads. Newer versions have option to disable compression in config file.
Seems like SPARC is troublesome platform for developer :|
