Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 29, 2011Aspirant
Easiest way would be to force that add-on to use plain http only, to get Loadavg to function properly? :roll:
EDIT:
Okay, got it all fixed (via small "hack"), maybe you could update this addon, and replace file security.php with this one:
http://www.upload.ee/files/1233034/security.php.html
All other files doesnt need to be modified and it works, like it should, also loadavg subpages now work properly :D
And it is Loadavg bug, not your addon bug, still lets make it work like it should... ;)
Also could you consider upgrading (or downgradeing to old version again) phpsysinfo to 3.0.10 and disabling JS compression in config file :roll:
EDIT:
