Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Bascy
Mar 29, 2011Aspirant
Thanks for the update ... alas a problem when using https:
Addition:
I noticed that config.xml.php doesnt contain a secure_conn setting, I added this myself
and now i'm getting this:
Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Addition:
$data .= "<setting name='secure_conn' value='on'></setting>";
Warning: fopen(http://updates.loadavg.com/version.php? ... 10.0.0.211) [function.fopen]: failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server Error in /c/webroot/loadavg/security.php on line 119
Warning: fclose(): supplied argument is not a valid stream resource in /c/webroot/loadavg/security.php on line 128
Warning: Cannot modify header information - headers already sent by (output started at /c/webroot/loadavg/security.php:119) in /c/webroot/loadavg/index.php on line 36
Warning: Cannot modify header information - headers already sent by (output started at /c/webroot/loadavg/security.php:119) in /c/webroot/loadavg/index.php on line 37
