Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 29, 2011Aspirant
Bascy wrote: and now i'm getting this:
Warning: fopen(http://updates.loadavg.com/version.php? ... 10.0.0.211) [function.fopen]: failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server Error in /c/webroot/loadavg/security.php on line 119
Warning: fclose(): supplied argument is not a valid stream resource in /c/webroot/loadavg/security.php on line 128
Warning: Cannot modify header information - headers already sent by (output started at /c/webroot/loadavg/security.php:119) in /c/webroot/loadavg/index.php on line 36
Warning: Cannot modify header information - headers already sent by (output started at /c/webroot/loadavg/security.php:119) in /c/webroot/loadavg/index.php on line 37
Have you tried my supplied security.php ? :wink:
Also I dont have "automatic update" in loadavg activated, will check that when I get home, maybe this is also causing somekind of issues... :roll:
Seems like Loadavg 1.5 is a bit buggy, but at least graphs display correctly now in firefox... :)
BTW, what version of PHP addon are you using?
EDIT: Its a problem with loadavg website, if I try this at work on my linux box, it also throws me Error 500, so better disable "updates" from settings and all works.
