Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 30, 2011Aspirant
Bascy wrote: Installed your security.php
removed secure_conn setting
charts are now working fine, but when i click on server or settings, i get the login-screen even though i havent set a username/password in the settings
BTW: i see no logfiles in the logs subfolder of Loadavg ... where are they saved??
logs should be in /c/webroot/loadavg/logs
For authentication, you should set user and password. Because its a GUI for modifying configuration and its always password protected ;)
