Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 30, 2011Aspirant
Bascy wrote: Also the phpsysinfo screen only showns a nice green background with the message "Loading please wait"
You could update It manually to 3.0.10 and it starts to work...
Only dont overwrite plugins folder, or you have to do lot of manual adjustments later... :wink:
Etz wrote: Also I guess phpsysinfo needs to be updated to 3.0.10, because DUO doesnt have "horsepower" to compress that amount of data and it times out and never loads. Newer versions have option to disable compression in config file.
Etz wrote: Also could you consider upgrading (or downgradeing to old version again) phpsysinfo to 3.0.10 and disabling JS compression in config file :roll:
Read previous posts in this thread :P
PS: It wont show you RAID status, if youre using X-RAID, because cat /proc/mdstat wont output anything about RAID level, because its NetGear proprietary and not standard.
