Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Mar 30, 2011Aspirant
Bascy wrote: Ok, got some info now, only missing Smart info
but have to look at that later .. gotto do some actual work now :-0
thanks for the support
For SMART info to display properly, modify SMART plugin configuration file: SMART.config.php (line 34)
(located at /c/webroot/loadavg/phpsysinfo/plugins/SMART/)
Issue is DUO doesn`t have /dev/hda & /dev/hdb as defined in there (at least if youre using X-RAID).
replace those with /dev/hdc & /dev/hde (or whatever your HDD device are, you can check it with fdisk -l) and it starts to display that information ;)
