Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also. It`s very outdated now... :oops: Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue. ...
Etz
Jun 21, 2012Aspirant
Enable HTTP from frontview and configure LoadAVG via web browser (Redirect error will go away) to use HTTPS only and then disable HTTP in frontview.
or another solution is edit LoadaAVG files directly and comment out http part or replace it also with https in security.php
If I remember correctly...unfortunately I switched to MRTG, so i cannot look from my config anymore... :|
Problem is that by default HTTP is disabled on ReadyNAS, only HTTPS is available (hence its a security reason), but LoadAVG needs HTTP by default.
There is HTTPS->HTTP redirect but unfortunately it goes into loop and never completes, and so the error is displayed, which you just posted...
It will happen on all browsers, only error message itself would be different... ;)
