lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
super_poussin
Aug 07, 2008Virtuoso
bad news
The following packages have unmet dependencies:
cherokee: Depends: libcherokee-base0 (= 0.5.5.dfsg-2) but it is not installable
Depends: libcherokee-server0 (= 0.5.5.dfsg-2) but it is not installable
libapache2-svn: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libbz2-dev: Depends: libc6-dev but it is not going to be installed or
libc-dev
libdb4.4: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libneon26: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libsvn1: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libxml2: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
ntop: Depends: libpcap0.7 but it is not going to be installed
Depends: libssl0.9.7 but it is not going to be installed
python: Depends: python2.3 (>= 2.3.4-18) but it is not going to be installed
subversion: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
