lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
_mj
Aug 08, 2008Aspirant
super-poussin wrote: duo reformated everything reinstalled but it's require pyhton 2.4.3 I can only install Pyhton 2.3 on Readynas :(
Can you even install Python 2.3? Could you please share how? I'm very weary of updating critical packages / dependencies. :)
nas:~# apt-get -s install python
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libapache2-svn: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libdb4.4: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libneon26: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libsvn1: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
libxml2: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
python: Depends: python2.3 (>= 2.3.4-18) but it is not going to be installed
subversion: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
