lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
PabloCreep
Jan 25, 2009Aspirant
thibs, I think I'm going to marry you.
I came across a couple of hiccups, but once I'd figured out I hadn't put uniq in the right place everything compiled. Had to obviously edit the sabnzbd file we created to match the IP of the readynas, and make it executable, and also change a couple of settings in the /etc/SABnzbd/sabnzbd.ini file to reflect the IP of the nas and changed the port... then we were flying. Top do - glad I, well, you, got it working!
Cheers,
Al
Cheers,
Al
