lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
bigred15
Feb 18, 2009Aspirant
PabloCreep wrote: thibs, I think I'm going to marry you.
I came across a couple of hiccups, but once I'd figured out I hadn't put uniq in the right place everything compiled. Had to obviously edit the sabnzbd file we created to match the IP of the readynas, and make it executable, and also change a couple of settings in the /etc/SABnzbd/sabnzbd.ini file to reflect the IP of the nas and changed the port... then we were flying. Top do - glad I, well, you, got it working!
Cheers,
Al
I've been trying to get this working and followed the guide line by line but I seem to be having the same issue with uniq. Once I get to the process of installing python I get an error regarding uniq but can't seem to figure out how to fix it. I am a total linux noob and could use any help you guys can give me to get sab installed on my duo. How do I get uniq in the right place? Thanks in advance.
