lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
GibberishDriftw
Apr 05, 2009Aspirant
thibs wrote: I wrote a full tutorial to install SABnzbd+ on a ReadyNas Duo :
http://www.thibernet.com/442-install-sa ... adynas-duo
Have fun ;-)
I got SABnzbd running on the DUO, using you tutorial, THX.
But I think the decoding and SABnzbd put to much strain on the processor.
My downloads are set to pause every couple of minutes, as I can see in SABnzbd
logging too, which leaves me with an average download speed of 700-800 KB/s.
I do have 1024 MB memory installed but no gain setting SABnzbd to using more
memory. Anyone got the same problem, or maybe a fix....
I guess I have to revert to NZBGet which does not have this problem, tho SABnzbd is
better with RSS integration, UI and possibilities.
What is the best way to uninstall SABnzbd, as the make command has no uninstall.
Complete reset to factory of DUO ? And then to copy all data back to it ?
Gibb
